Do you have a home router?  If so, restart it and see if that fixes the problem.  Can you check to make sure the Wi-Fi is not down by looking at a cell phone or tablet that has Wi-Fi.
Workstation PC Specs: CPU - i7 8700K; MoBo - ASUS TUF Z390; RAM - 32GB Crucial; GPU - Gigabyte RTX 1660 Super; PSU - SeaSonic Focus GX 650; Storage - 500GB Samsung EVO, 3x2TB WD HDD;  Case - Fractal Designs R6; OS - Win10
  • 4 weeks later...
What is happening is my computer isn't even trying to connect to wifi, there is no menu
We need details to help you. A parts list, model number, anything.
Does WiFi work on other devices and just not your computer?
Have you checked in Control Panel\Network and Internet\Network Connections and looked to see if the WiFi adapter is present, disabled, enabled, etc?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
On 2/14/2020 at 5:29 PM, Srijan Verma said:
details?
F@H
GPD Win 2
