I have a Asus Sabertooth Z77 motherboard  with a I5-2500k and 8gb of ddr3 ram i have plugged in the 20+4 pin power and 8pin cpu the power led on the motherboard lights up but when i roll over the pins with a screw driver nothing happens any advice?A refund would be my last option testing on a cardboard motherboard box
https://linustechtips.com/topic/1155398-help-pls/
12 hours ago, M0SIE said:
No but i very sure the problem isnt the psu
You sure that you tried to short right pins for power switch ? Check the pic1 for right ones. Also you can trie clearing cmos if you didn’t do it before.
Do you have speaker connected to the mobo? Is there any beeps?
Last you can try with memory button (pic2)
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1155398-help-pls/#findComment-13296935
  • 2 weeks later...
