Hello...i am going to build my first ever pc after doing some research i have found out the following parts to go for.. I wanted to ask if these are compatible with each other...and are these the better ones out there as there are others also(asus,gigbyte,msi etc) and i dont plan on upgrading any thing for 3 to 4 years...so are they future proof I am going to use the pc for gaming ,3d modeling video editing,streaming etc
.Amd ryzen 7 3700x
.Msi b450 tomahawk
.G skill 8x2 (3000mhz)
.Msi ventus gtx 1660ti
.250gb SSD samsung 860evo
.1 tb HDD seagate barracuda
.650w corsair power supply 80+bronze
.Coolermaster NR600 case
Also should i go for the r5 3600...as its cheaper...but its mainly beneficial in games but i dont plan on playing any hardcore games...just some fortnite,dota,cs go etc...but my main work is video editing and 3d modeling
https://linustechtips.com/topic/1153880-my-first-build/
would personally go with faster ram, a better ssd. and which corsair PSU ?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13283423
actually if you wanted to save money, go for the 1660 super instead of the TI. Not only is it cheaper for almost the same gaming performance, but the memory bandwidth is better which means it might actually improve your 3D modelling workflow.
You also don't need anywhere near 650 watts, a corsair CX550 would be fine.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13283427
I want to be future proof thats why i am going for 1660ti ....and is 650w to much as i also want to future proof it too
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13283453
nothing is future proof. Like I said, the 1660 super might actually be just straight up better for you, here and now.
My own rig is in my signature down below, along with power draw. Trust me, it's very difficult to build a PC that consumes 650 watts.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13283459
13 hours ago, Talha1122 said:
What speed ram would you recommend and isnt the 860evo a good budget ssd ...the nvme is a bit overpriced for my budget
where are you located?
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13284716
1 hour ago, Talha1122 said:
Pakistan
if you are on a tight budget on the ssd then the samsung is fine, is the 3200 Mhz ram way more expensive? i would get something in the 3200mhz to 3600 mhz range
here's a video about ram speed
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13287471
A powersupply can be passed from built to built for decades so I would go with more than you need and check where its most efficient, too.  Some PSU's are more efficient at 80% of rated output and some are lower or higher in that range.
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13287634
Decades? No. Most power supplies are not trustworthy after like 7 years, and after 10 years it's time to put it out to pasture. As for upgrade capacity, see my signature below for an example. I highly doubt OP would be building a rig that consumes over 550 Watts
The difference is so tiny that it doesn't matter at all. Overspending for that "sweet spot" doesn't yield any benefit.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13287647
I would never recommend someone cheap out on their power supply.  Just because current hardware is so efficient doesn't mean it's going to stay that way and what if SLI makes an unlikely come back?  A 500watt power supply will limit their hardware in the future.   I wouldn't throw away a good power supply just because it's 7 years old.
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13287664
Buying a less expensive version of the same power supply is not "cheaping out," it's budget friendly. I can never advise "future proofing" by getting a more expensive PSU, because it's money spent that doesn't go towards any benefit
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13287697
The price range for PSU isn't large so spending an extra $20 isn't going to kill anyone.
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13287727
my point is that it's a wasted $20
that's like a whole 4 subway sandwiches!
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153880-my-first-build/#findComment-13287731
