Hello LTT Forum, I just wanted to share my new build and hear some feedback on what you all think. Cable management isn't perfect and there's some additions I want to make in the future but I think it turned out pretty decent.
The RTX 2060 and 3600X being on sale is what did it for me. My wife and I will be playing lots of BL3 and who knows what else :D (Want to buy Metro Exodus and Cyberpunk 2077 when it gets here!)
Only issue is that iCUE and MysticLight hate eachother :(
Parts list and more pics: https://pcpartpicker.com/b/mLvnTW
Thanks to LTT, JayzTwoCents, Gamers Nexus, HardwareCanucks and Hardware Unboxed for hours of great content that helped me build this rig!
https://linustechtips.com/topic/1153535-my-first-build/
the dream
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1153535-my-first-build/#findComment-13281027
Nice and clean!
You have only 3 intake fans?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1153535-my-first-build/#findComment-13281038
2 minutes ago, JDNightbot said:
@Constantin I plan on adding 1 rear exhaust fan in the near future but I thought 3 intake was enough...?
One rear is not enough, at least 1 back exhaust and all the other you can add, intake, like top, bottom
https://linustechtips.com/topic/1153535-my-first-build/#findComment-13281074
I have 2 intake and 1 exhaust on my PC, no thermal issues whatsoever
But if OP wants their PC to sound like a helicopter taking off, it would be a great idea
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153535-my-first-build/#findComment-13281117
12 minutes ago, Max1996LTT said:
Wait, wait, wait...fans at the top for intake? Seriously?
YES!
https://linustechtips.com/topic/1153535-my-first-build/#findComment-13281144
So are you saying I can do 2 intake and 1 exhaust in the top together? like //back to front (1 ex) (2 in) (3 in) - would that cause airflow issues?
https://linustechtips.com/topic/1153535-my-first-build/#findComment-13281157
3 minutes ago, Max1996LTT said:
Yeah...No. Front and side are for intake. Back and top, exhaust. It really can't be simpler.
Is that so?? Have a look at cmy py set up in thew gallery to enrich your way of thinking
https://linustechtips.com/topic/1153535-my-first-build/#findComment-13281163
23 minutes ago, Max1996LTT said:
Err...what?
Edit: Is that so?? Have a look at my PC set up in the gallery to enrich your way of thinking
https://linustechtips.com/topic/1153535-my-first-build/#findComment-13281239
Looks clean, just take one intake fan and mount it in the rear for exhaust for now.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1153535-my-first-build/#findComment-13281313
Congratulations. Welcome to the PC master race.
8 hours ago, aisle9 said:
A turd with an HDMI cable jammed into it is more powerful than a MacBook Air, and up until this year it had a better display, too.
☢️ Know Your Allergens: ☢️
Pollen | Plastic | Radiation | Antimatter
part list
https://linustechtips.com/topic/1153535-my-first-build/#findComment-13282139
