Hello guys!
I'm new to overclocking and stuff, but i have an i5-2500k with the H61H2-M10 (ecs) motherboard, When i try to overclock my cpu, the cpu multiplier is locked at 33
I'm not sure if the problem is that my motherboard isn't OC compatible or not, it says it can do on the manuel.
I tried installing the xtu thing, and same thing, my max multiplier was 33.
Can u help me?
Thank you for your time.
https://linustechtips.com/topic/1153197-i5-2500k-overclocking-problem/
Only Z chipsets are overclock-able.
You need a Z68 or Z77 board to overclock that chip.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
they most likely just adapted the manual from a board that does support overclocking, which this one doesn't.
For LGA1155, Z and P chipset boards can overclock non-K CPUs by 400MHz, but not the other way around.
Desktop benching:
Make sure Intel Turbo Boost and the C states are enabled in the bios.  You cannot overclock with this motherboard but when setup properly, turbo boost should give you an increase in MHz.  Up to 3700 MHz when 1 core is active.
http://www.cpu-world.com/CPUs/Core_i5/Intel-Core i5-2500K CM8062300833803.html
