Alright, I just had a question about setting up a wired internet connection for all devices in a older household. I'm VERY new to this sort of stuff and have no idea what I am talking about, so please be understanding. I just got done watching the video where linus set up that storage system for iJustine and got to thinking.
My house was built in 1995 and doesn't support really anything interesting. We recently converted to a fiber optic internet company (Utopia) and I was wondering if there was a way to convert all the old phone jacks into a port for internet as all of our devices are using wireless (Except the one computer next to the modem). Do you know of any way to set that up? It seems we already have a network switch installed, which is receiving signal from the modem and then sending a signal into a converter(?) for our phone lines.
Any advice or help is greatly appreciated, Thanks!
https://linustechtips.com/topic/1152995-ethernet-conversion/
Not really, a lot of old phone wiring isn't even twisted pair.  I have a house from like 1997 and its this way, just straight phone pairs that would be garbage for data.  A lot of older houses also didn't contain 4 pairs of wires and would do one or two pairs as old phone lines would only need 2 wires per line.  Some newer constructions have been using cat5e which you can sometimes reterminate, but if it's daisy chained between outlets then that's also a bust.
Realistically you'd be running new cabling so you can leverage higher data rates over twisted pair cabling.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
https://linustechtips.com/topic/1152995-ethernet-conversion/#findComment-13277011
your most likely just going to have to run new line. I'd do cat 6A but cat 5E is a little cheaper.
Cat 6A will be better if you ever want to run 10gb or even 1gb over super long cables.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1152995-ethernet-conversion/#findComment-13277035
So, If I replace the existing line with cat6a It should work fine? That sounds like a difficult but doable job. Ill have to think about it.
https://linustechtips.com/topic/1152995-ethernet-conversion/#findComment-13277122
you'd need new line and wall plugs. something that maybe possible, is you attach the new cat cable to the old phone cable and pull the old out while running the new.
https://linustechtips.com/topic/1152995-ethernet-conversion/#findComment-13277128
Assuming they aren't daisy chained, yes.  You'd need to have all of the runs terminate into a similar location and not hanging off of each other.
https://linustechtips.com/topic/1152995-ethernet-conversion/#findComment-13277336
