My brother has been thinking of getting a graphics card. AMD's RX graphics cards have a game deal going on. My brother has a dell inspiron 3670. Do you guys know if any of the XT graphic cards are compatible with my brothers pc. If I have stated anything wrong please tell me. Also will these cards run Half Life Alyx?
Sorry I am not experienced when it comes to computers. All I have done is replace a fan and add ram to my laptop. Thank you
https://linustechtips.com/topic/1152543-i-need-help-i-know-nothing/
Most likely not. At least it has a usable PCIe slot (since it could come with a GT1030 card) but I doubt it has PCIe 6pin needed to power at least the RX 5500XT. You have to check that.
Half Life Alyx should be playable with an RX 5500XT but it may need minimum graphics settings, the game is not out yet so there's no testing data available.
Desktop benching:
Type This PC into the search bar, then right click the icon that comes up and select Properties - what kind of hardware are you rocking?  Can take a screenshot if you then search for Snipping Tool in the search bar and taking a screenshot and showing us.
What size tower, there are a couple variants of this tower (mid, mini etc)
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Maybe an external power supply to feed the v-card? It's kinda crazy but It'd be interesting
I hope I have done it right. Here you go
Edited by HELP290
Someone said I should delete the image
-snip-
Actually go ahead and delete not sure if that product ID matters, I got the info I needed (CPU and RAM)
Open the side panel on the computer, and take a picture of the inside so we can see what kind of case/space you have avail
Its an i5 8400 with 12gb of 2666mhz ram.  From Dell site it appears to be a mid atx case.  We need to figure out what power supply is inside if you can take a pic of the unit once side panel is off clear enough to see the specs of the PSU, then an overall shot of inside the case so we can tell you how to get measurements if it looks tight
Good ol' proprietary shenanigans!  So that PSU is not an ATX PSU and its rated at 290w - without spending a ton of time, its not going to be a great PSU to keep in the unit should you put a GPU in that requires power draw.  But that likely isn't going to play VR really well (I believe Alyce is VR only?).  So a slot powered card would be the only recommendation I could make without replacing the PSU (which will take some adapters and rewiring to do).
I think the best slot powered card you have as an option is the GTX 1650.  Im not sure that's a VR capable card, as its 50% slower than my Fury's which I would call barely capable VR cards.
From what I can tell that PSU is 4 pin CPU 8 pin mobo proprietary PSU for that board or similar, as ATX standard is 24pin for the board 4+ pins for CPU (basically)
I have actually built a custom gaming rig for fun out of similar (custom loop, GPU, ATX PSU conversion) in a proprietary mess of a computer, Ill put a picture below
To get an ATX PSU to power a GPU effectively you have two options:
Research an adapter that works a 24pin ATX PSU down to the connectors used on your specific mobo - this is the one I used (I believe) for my conversion:
https://www.ebay.com/itm/for-HP-Elite-8100-8300-8200-800GI-E-PSU-ATX-24-Pin-to-6-Pin-Power-Adapter/133261304022?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20131003132420%26meid%3D85c6eb9905aa41b8a291f8bdc2233db6%26pid%3D100005%26rk%3D2%26rkt%3D12%26mehot%3Dco%26sd%3D324038467889%26itm%3D133261304022%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100005.m1851
Then you can get a standard ATX PSU that has PCIe power so that you can put an appropriate PSU for gaming in the rig.  I.E. a Corsair CX550 or so.
Now, I must state - the adapter swap I did to my for fun rig, blew the PSU in 6 or so months.  So not sure if it was the fact I used an old PSU from the parts pile or the adapter caused it to blow.  I semi blame the adapter as it was a previous Tier A PSU.
OR the other jank way
Buy another PSU and run it from a wall socket and route the PCIe power to the GPU inside the case through PCIe slots on the case or leave the side panel open.  The second PSU will power the GPU while the one that came with this rig will continue to do its normal thing.
In the end, this is a proprietary case, Motherboard layout, PSU so the ability to DIY is limited to how much you are willing to do to this rig to get it to work.
Since I talked about it, heres what mine ended up looking like when I was done with it (circled in red up top is the 24 pin connection adapter to my board that was 6 pin + 8 pin I believe (don't have time to get it out and take it apart and look):
EDIT - I need to also say, I had to rewire that adapter after researching my boards pinout, and my PSU pinout, so it did NOT work out of the box either for my situation and required more DIY than just a plug and play solution
