I have a MSI Z87-GD65 I have looked at their list of approved memory, but still having issues picking out the right memory. I am either going to do a total of 8 or 16 depending on price, and yes I would like to overclock the board. Help. I have been looking on newegg
https://linustechtips.com/topic/115163-memory-help/
it doesnt really matter.
just get some cl9 1600mhz 8gb kit. Like Vengeance pros.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/115163-memory-help/#findComment-1539604
put one thing in you'r mind more than 8GB for memory wown't mater becaus it's like a limit for it, so any thing more than that  you'll barly notice any difrance in performance but if you inciste get 16GB so you can u^grade later to 32 GB without running into compatibilty issues
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/115163-memory-help/#findComment-1540603
Here's the memory I'm currently using in my system, it has a speed of 1600 Mhz.
Kingston HyperX Blu Black 8 GB RAM kit http://www.canadacomputers.com/product_info.php?cPath=24_311_312_612&item_id=058485
Kingston HyperX Blu Black 16 GB RAM kit http://www.canadacomputers.com/product_info.php?cPath=24_311_312_612&item_id=058484
The 16 GB RAM kit is CL10 RAM though so it will give you better performance. I'm using the 8 GB RAM kit in my system though and it performs fine.
Hope this helped.
https://linustechtips.com/topic/115163-memory-help/#findComment-1541127
Go with 16gb dual channel kits for future proofing. Corsair RAM is typically overpriced, look at G.Skill, Kingston or Mushkin. Don't waste your money on high speed kits, they tend to have looser timings. Get 1600 or 1866 MHz speeds, 2133 OK but not needed. Pay attention to the Cas Latency/timings...the lower the better.
https://linustechtips.com/topic/115163-memory-help/#findComment-1541716
