Sets all cores to the single-core boost frequency IIRC, with overclocking I assume it's useless.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
It's a mobo overclock, where it will set the all core clock to match the single core turbo speed, and increase the voltage most likely more than is needed. If you're manually overclocking you're probably overriding it.
i did monitor the voltage and at one point my vcore was at 1.45, doesnt seem very safe! No point having it on then
You should be able to reduce it. Motherboards can overdo voltage settings.
