Hello
I have a pc and have been downloading some games
My wifi provider say i am get 70mbs yet when i download i only get 635kbs
but when i look in my adapters download it says 60mbsWifi.PNG.5021c5abb5ec600d6f35b1d00c22e6e1.PNG
I am using a wifi card if anyone could help me it would mean a lot
i can discord call if required
Thank you,
Ben
Stats.PNG.38f5be71d0f0260ae73785a3b645c48b.PNGWifi.PNG.5021c5abb5ec600d6f35b1d00c22e6e1.PNG
Edited by BigBadBen
Adding Tags
https://linustechtips.com/topic/1151481-i-need-help/
That looks like some problem with the wifi connection. So wich wifi router do you have?
Is it capable of wifi n or better yet ac?
Over wich wifi standard are you connected to it? That looks like wifi b or something old and slow.
Can you get better speeds with other devices and over wired LAN?
Also try to update the drivers for your wifi card and firmware on your router.
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1151481-i-need-help/#findComment-13264781
I use fast.com  to make sure if it's problem on my end...Could always be a slow host server.
Better use an ethernet cable for higher speeds.
If speed is low even with wired connection, reset the router and maybe move it around the house to get a better signal or even attach external antenna.
https://linustechtips.com/topic/1151481-i-need-help/#findComment-13264805
They're asking what model your router is.  The sync rate you're observing is pretty low, if it's on the 2.4 GHz ISM band like a single band N router then it's going to also exhibit more interference and lower speeds in addition to the lower sync speed you see.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
https://linustechtips.com/topic/1151481-i-need-help/#findComment-13264912
12 minutes ago, BigBadBen said:
THIS IS MY ROUTER
That's not a model number. the model number should be on the bottom of the router itself.
It's a BT something, probably a Hub 3 or Hub 5 but we need more information.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1151481-i-need-help/#findComment-13264967
31 minutes ago, BigBadBen said:
THIS IS MY ROUTER
All I see is a SSID bro.  The network name is not the physical model of device of the router.  I can only assume it's the cheapest ancient box ever that only offers a single stream of 2.4GHz N which would cap out at a 65 or 72 mbps sync rate, which is complete garbage.
Do you just receive wifi from an apartment complex or something?
https://linustechtips.com/topic/1151481-i-need-help/#findComment-13265015
