27 minutes ago, boggy77 said:
is this for gaming? is that your budget? if I were to optimise it, would you prefer to make the current one cheaper, or keep the budget and make it better?
I'll be using mostly for gaming and some general use. I think I'd rather make it cheaper. But I'll have to wait and see what my dad says, he'll be paying for part of it. Thanks for the advice!
https://linustechtips.com/topic/1150561-mid-range-build/#findComment-13257943
