Hi,
I Have An Asus ROG G20aj.
I Am Using All Original Parts And Have Kept The Inside Very Clean.
However My Motherboard Sensor Apparent Says My Motherboard Is Hitting 110 Degrees.
At First I Thought It Was The GPU Power Issue Because It Has A 240w Power Supply Running A GTX-750 2Gb.
Well I Took Out The GPU and Booted And The Temp Is Now 118 Degrees.
I'm Pretty Sure This Is Just An Error, But Any Considerations Would Be Appreciated.
https://linustechtips.com/topic/1150392-motherboard-overheating/
Yes it probably is....
EDIT: Use HWINFO64, from the best and accurate sensor software.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
the sensor could have failed, and is just spitting out garbage data now. The trouble is knowing where the sensor even is to double check with a different measuring instrument
is the cpu throttling thanks to this false sensor reading? I know macbooks take a giant dump when there sensor fail
So Far Not Really Noticing Any Drops, It's Performing As Expected And Just Really Gets On My Nerves Knowing It's There...
I Like Afterburner But Something Is Wrong With Their Website, I Have Tried 4 Different Computers And All Of Them Freeze On The Site
