Ryzen 7 3700x + Aorus b450 pro wifi motherboard+ corsair vengeance 8 gb x 4 rams of 2400mhz
Go to solution Solved by Diwakar A S,
20 hours ago, Fasauceome said:
not saying they're broken, maybe just having compatibility problems.
even if they're new, DOA, or dead on arrival, parts are not unheard of. It is possible to buy a component and it is broken already, in which case you could take it back to the store and get a refund
though I will say, 2400MHz is very slow for Ryzen so maybe bring them back anyway
All the issues got resolved after updating bios from f41 to f50.
I went to Gigabyte service center & everything is solved now.
If that's the case then it's almost certainly a motherboard manufacturing problem with either slot 2 or 4, or both. Simply open up an RMA case with Gigabyte and ask for it to be replaced.
CPU: AMD Ryzen 7 3700X - CPU Cooler: Deepcool Castle 240EX - Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 2 x 8GB Corsair Vengeance Pro RBG 3200MHz - GPU: MSI RTX 3080 GAMING X TRIO
Hi.
I was having BSOD on my new build.
Tried everything but nothing worked.
Finally, updated bios from f41 to f50 from Gigabyte service center & all the issues are gone.
All 4 rams are working in the system too.
P
* Threads merged *
There's no need to make multiple threads about the issue, and to make a separate thread for the solution.
If you need help with your forum account, please use the Forum Support form !
2 hours ago, wkdpaul said:
* Threads merged *
Sorry for that,I was just trying to help others.
If anyone has same issues,this might help them.
People will search for the issue, not the resolution.
Posting the resolution into your thread is enough since people with the issue are going to find that thread and look if there's a posted solution ;)
