Hi,
I have i7 9700K running @5.2ghz 1.36v LLC 7 cooled by 240MM AIO.
i changed the AIO fans for normal but RGB case fans for better looking CPU, i started getting BSOD, crashes and restart although CPU tems are normal and never exceeded 65c, i clocked the CPU back @5.ghz and LLC 7 and now all went to normal?
is thia normal for the PC to shutdown in this case although temps are fine? does the system predicts that the CPU will overhheat so its shut down?
https://linustechtips.com/topic/1149061-strange-cpu-system-behavior-causing-bsod/
Where are you getting your CPU temps? The overall temp of the core or averaging things out?
It is possible there are other things going on. Over current for example. Not sure.
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
hwinfo, all cores are below 65! dont know really!
Hm... Maybe a current cutoff? Hard to tell really. I am honjestly not familar with the 9th gen setups. My experience was with Z77 before I moved to my x570 and 3600X XD
