First a couple of notes:
I have an ok system as is but think my hardware is beginning to show signs of aging. Aside from some slight system instability (aka random hitches in the otherwise smoothly running system, as well as random slow boot times for no discernable reason) the build I currently have suits my needs. As always faster would be nice, but overall my use for gaming and some blue ray backups/compression and general home pc use, my current hardware is adequate. Since I haven't found any software issues however, the buggy system is making me want an upgrade. I dont really want to start over since most of my secondarry components(GPU, psu, m.2) are newer(within the last year or so) but wouldn't mind the upgrade to a better platform. So below are my current specs, my ballpark budget, and what I am considering. Any suggestions are welcome as well as ideas on what is causing my current issues.
My current system:
Core I7 6700
MSI Z170A GAMING M3
2x  CORSAIR 8gb ddr4 2400 (16gb total)
EVGA GeForce RTX 2060 SC GAMING, 6gb
Coolmax 900w
WD_Black SN750 1TB NVMe SSD
HDD 1 TB SATA3
COOLERMASTER HAF-XB
Windows 10
Ballpark budget: 500 - 700 US $
Options:
Asus ROG X570 Crosshair VIII Hero (Wi-Fi) ATX Motherboard
AMD Ryzen 7 3700X 8-Core
G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 Memory
Pcpartpicker link:
https://pcpartpicker.com/user/Dodeedo351/saved/wYsYgs
https://linustechtips.com/topic/1148953-system-updateupgrade/
You don't need such an expensive mobo
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor $324.99 @ Amazon
Motherboard Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard $189.99 @ B&H
Memory G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 Memory $109.99 @ Newegg
  Prices include shipping, taxes, rebates, and discounts
  Total $624.97
  Generated by PCPartPicker 2020-01-25 11:48 EST-0500
https://linustechtips.com/topic/1148953-system-updateupgrade/#findComment-13245109
Fast 4/8 isn’t dead yet for gaming.  Things are definitely headed in that direction.  Hasn’t reached it yet.  Until games outstrip your core count it will work fine.  Your cores are pretty fast.  You just don’t have a lot of them.  I doubt you would see much if any actual speed boost in many games.  Might make a difference for some heavily cpu dependent games that use many multiple cores well.  It’s a bus that will need to be jumped on eventually most likely.
https://linustechtips.com/topic/1148953-system-updateupgrade/#findComment-13245149
