Idk where to put this but rn I have a shitty GPU idk what it is but am upgrading to a nividia 1060 super 6gb but I only have a 450w psu should I upgrade or not I'm very new to owning a PC my CPU rn is a ryzen 5 2600 and I have 1 SSD and 16gb or ram
https://linustechtips.com/topic/1148895-help/
What is the power consumption normally? Then, see what the new cards power consumption is. It might not run so you possibly could need a new PSU.
https://linustechtips.com/topic/1148895-help/#findComment-13244723
1060, 2060 or 2060 Super? What PSU do you currently have exactly?
Edit: Yeah no, you will want to upgrade that power supply. A good fairly inexpensive option would be a CX550 from Corsair.
Edited by Mateyyy
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1148895-help/#findComment-13244729
Just now, Zytex said:
A 450w tharnalake light power
That's generally considered a pretty poor quality PSU. I would look at a CX450 or CX550 for cheap.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1148895-help/#findComment-13244734
Just now, 2011PCGuy said:
I believe he either mean 2060 super or 1660 super.
Yeah I forgot about the 1660. They just have so many '60s nowadays lol
https://linustechtips.com/topic/1148895-help/#findComment-13244735
What if it was a 650w tho
wattage doesn't matter, it's the fact that the quality of the power supply and power delivery is bad which can lead to a large number of different issues. It's not going to burst into flames but some fluctuations in power or other issues could take it out and other components with it.
Prior Build Log/PC:
https://linustechtips.com/topic/1148895-help/#findComment-13244741
2 minutes ago, Lurick said:
wattage doesn't matter, it's the fact that the quality of the power supply and power delivery is bad which can lead to a large number of different issues. It's not going to burst into flames but some ripple or other issues could take it out and other components with it.
Do you reakon cooler master psu are good
https://linustechtips.com/topic/1148895-help/#findComment-13244748
Brand does not mean good. it depends on the series.
There is a good list here:
Prior Build Log/PC:
https://linustechtips.com/topic/1148895-help/#findComment-13244750
DEFINITELY!!! Yes and at least a 650w to give you a little brim.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1148895-help/#findComment-13244798
He doesn't need anywhere near 650W.  You don't use "a little brim".  LOL!   You either have enough power or you don't.
If you have enough power, but it's a crappy PSU, then he's either slowly killing his other parts or is in store for a short product life.
He just needs a better PSU.
https://linustechtips.com/topic/1148895-help/#findComment-13245226
Don't want to sound like a jerk, but... I have noticed, you like to recommend ridiculously oversized PSU s. Why?
A 400w psu is perfectly enough for 1660Super/1660ti,  1060 GPU. Those cards draw roughly 130w under Fürmark..
I have a buddy, who even ran a 1070ti on a 400w unit... Without issues
Life is really challenging. I don't always suceed: )
https://linustechtips.com/topic/1148895-help/#findComment-13245313
