Problem after replacing the same motherboard
Go to solution Solved by ddennis002,
Just now, Constantin said:
I never used a VPN service, how come it is there?
Like i said usually windows also has a virtual tunnel that is built into windows could be for that. It is safe to remove it though.
Hello!
So i had an issue with my motherboard that finally got fried from the UPS (quite old 13y/o).
I got a new one (same as it was RMA) replaced it and everything is back to normal, didn't even have to fresh install the Windows.
But i have a little problem, have a look in the picture.
There is that error in the PC icon saying no driver ect....
If someone had run in to the same problem, any help will be appreciated
PS: The PC run 2 days now and everything runs fine....
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
26 minutes ago, Constantin said:
Hello!
Check under device manager and see if you have a device driver that is missing.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
It doesn't say what it is.....
And everything that i have installed work fine
This really puzzle me, all my devices are working just fine, keyboard, mouse, printer, sata drivers, chipset driver, Lan driver, wifi driver, Bluetooth driver, mouse pad driver, audio driver.... i really can't imagine what is that missing unknown device......
So pretty easy way to figure out what these are
In device manager right click and select properties on each of the unknown devices. Go to the Details Tab and under the property drop down select Hardware ID's.
Under the Value right click the top or only entry and copy and paste into search engine and this should give you a good clue or direct answer to what these devices are, once you know that then you should beable to deal with them accordingly.
Internet Connection
Passmark Score
3dmark Score
Network
It's saying plun0901
ptun0901?
Internet Connection
Passmark Score
3dmark Score
Network
Just now, ddennis002 said:
ptun0901?
That is a virtual tunnel driver for virtual network adapter usually installed with a VPN provided,
Internet Connection
Passmark Score
3dmark Score
Network
Internet Connection
Passmark Score
3dmark Score
Network
Thanks!
