How to learn to code?
Go to solution Solved by RadiatingLight,
you just have to make a lot of stuff
Try making a basic interface with tkinter, learn stuff along the way.
try making a tool that can view (or modify) file properties, learn stuff along the way
try making a "game of life" type thing, or cookie clicker, learn stuff along the way.
rinse and repeat until you are the next steve jobs.
Learn to code or learn about complex software?
https://linustechtips.com/topic/1147750-how-to-learn-to-code/#findComment-13235277
Just now, Mark_C said:
I already know basics but want to progress into more complex
Well, what do you know?
https://linustechtips.com/topic/1147750-how-to-learn-to-code/#findComment-13235287
Basic Python and basic Java
You're not going to get into complex software really with just knowing base stuff
How much do you know of each?
https://linustechtips.com/topic/1147750-how-to-learn-to-code/#findComment-13235293
1 minute ago, Mark_C said:
Well right now im about 25% complete for both on Codecademy
Being not familiar with codeacademy I can't really use that as a benchmark.
But if I had to guess, you're nowhere near what it would take to tackle complex systems
Finish those courses and move to C
https://linustechtips.com/topic/1147750-how-to-learn-to-code/#findComment-13235307
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1147750-how-to-learn-to-code/#findComment-13235308
well along with codecademy or instead, is there anyway you suggest I can learn better or more efficiently?
https://linustechtips.com/topic/1147750-how-to-learn-to-code/#findComment-13235321
Like, the courses are just a guide to give you a path
You can move to new topics and try to learn how to use them efficiently at any point. If you're a reader, there's plenty of textbooks you can run through
https://linustechtips.com/topic/1147750-how-to-learn-to-code/#findComment-13235323
Would you happen to know if Kahn Academy would help me progress better?
https://linustechtips.com/topic/1147750-how-to-learn-to-code/#findComment-13235336
Probably not revelant. But if you learn under preassure. You can design your own "complex" program and make it as you learn.
Of course this will demotivate you alot if you give up easily, but if you have the "I can do this" mentallity, and dont break on the way. You definitely can make somewhat complex programs along the way.
Anyways if you take this route. I would advice you to stay with one program, and don't give up untill it's done.
https://linustechtips.com/topic/1147750-how-to-learn-to-code/#findComment-13235339
Maybe? I don't know how you learn
They don't go to a very high level and focus is primarily only around web based languages
Plus I don't believe they do anything near C, Java or Python
https://linustechtips.com/topic/1147750-how-to-learn-to-code/#findComment-13235347
