Here is a link to my updated build: http://uk.pcpartpicker.com/user/Gazzer96/saved/1f7I
I am getting a Nocuta CPU cooler, but I am worried about the size of the thing because the case I am going with has a large fan on the side panel; I'v done some research on how large it is and there is only going to be 200mm of space, but this does not include on how much space the fan takes up. I need to if I should get before I end up buying it.
If you know any better cases for around £100/$154.87 please do tell me.
I will appreciate it if you could help me out. Thanks!
https://linustechtips.com/topic/11475-need-help-with-cpu-fantower-case/
