Posted January 20, 2020 So I just upgraded my motherboard (b450 carbom pro) and cpu (ryzen 5 2600x). I have connected all the wires and everything is good to go. The computer starts but I have it connected to my tv with HDMI to the integrated graphics. There is a random red light staying on at the side of the motherboard (not part of RGB lighting) and I get no signal to the tv. I am still using the same hard drive and everything so I really do not know what is going on. There is a flash bios button but I have no idea what that will do since I have never done anything like that before. Is there a step that I am missing or one that I do not know about? Any help would be greatly appreciated. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 20, 2020 If I am reading the spec page correctly on that Motherboard. It doesnt have an internal GPU. It supports AMD APUs, but doesnt have internal graphics, you need a graphics card or an APU. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 20, 2020 Author Hmmm, so why would they put an HDMI port on the IO panel if it cannot be used? Or am I misunderstanding? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 20, 2020 When you have an APU in the system, it would be able to be used. You dont have an APU in there, so it cannot be used. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 20, 2020 Author Okay I think I understand now. I just want to make sure though. As long as I get a GPU I should be okay correct? I was trying to hold off on getting it to save up some money but if I have no choice then I want to make sure I won't need something else after as well Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
