EATX case for 3970x (with proper airflow)
Solved by Guest,
12 minutes ago, Guy Marshall said:Yeah it's super annoying! It's almost like they build a standard glass case and make a more expensive one with actual decent airflow to get you to pay more!
I am guessing it will still fit an EATX motherboard even though it is only ATX?
The Enthoo Pro II is actually going to be a bit cheaper @ $130. Idk what the Level 20 pricing was. Oh darn. There was no info on it before, but now I see the RS doesn't fit E-ATX. Bummer. I must have assumed it was the same size as the glass front E-ATX case I saw next to it in someone's coverage video.
