Was trying to overclock my build for the first time on my 2700x but every time I would restart it would freeze before booting windows or it would get to windows but it would freak out
cpu: r7 2700x (working @3.8ghz)
mobo: ASUS Strix b450-f gaming
cooling: corsair h100i
ram: 16gb
https://linustechtips.com/topic/1145704-help-with-overclocking/
ram: 16gb
Btw I tested going back to base clock, works fine
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218822
ram: 16gb
Seems like you didn’t done it properly. Reset the oc and start from scratch but make sure you watch some tutorials how to donit if you not sure
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218827
just decrease the overclock, try half of what you did previously and see if it works, if it looks like it does, let it run for 20min, if it still runs, try to stress test it to make sure it's stable, if it's stable, you can try increasing it, if not, decrease. Rinse repeat until you find a sweet spot for your CPU.
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218832
Ok I’ll tell you what happens
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218838
What voltage settings are you using?
I ran into BSODs when I was adjusting the voltage but didn't limit the clock speed, so every time the CPU went too high, it crashed the computer.
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218859
that just means your overclock is not stable. Not all CPUs can run even a little bit faster than it does at stock
Desktop benching:
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218865
4 minutes ago, Ashton216 said:
Cpu, I’m going to try and up the clock speed slower instead of pushing it this time
So you're doing a static overclock? (manual)
Ehh, you won't beat out the SenseMi overclocking ability on that motherboard.
So at 4.0 to 4.1ghz manually, you want a cpu v-core of 1.410v.
4.2ghz looking around the 1.450-1.4750v range. (yes it gets hungry. All cores and threads active require more current)
4.3ghz.... looking at qround 1.5-1.5250 v-core......
At least that's my experience with it.
However, if you want some tips and tricks tweaking the SenseMi technology, I can head you in the right direction.
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218867
I am using an automated setting for my mobo, however I think I solved the issue because there was a setting that was not supposed to be changed, thanks
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218868
I think I solved the issue because there was a setting that was not supposed to be changed. Thank anyway though
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218870
After looking at a tutorial on YouTube, I was told that if you set a target clock speed, but keep the voltage on auto it will adjust fairly well on my mobo. I tried it and it seems to be working now, thanks.
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218877
Try performance enhancer level 2. Everything else on auto.
If you have SensiMi offset in tweakers paradise, you can set higher than 272 (default) which will increase all core and low level clocks. I change this setting to 290 and it seems to do pretty well. (do this seperately from performance enhancer all else on auto)
The max I can squeeze from my chip with v-core on auto is 4.1ghz static. Anything higher, must manually increase voltage.
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218901
Seems like you have a bad overcloker.
My 2700 non X can go 4GHz allcore @1.35V stable and even 4.1GHz, but that is slightly unstable.
Have you tweaked your LLC? Cause those voltages seem very high if you also have an agressive LLC
My Gaming PC:
Inno3D iChill Black - RTX 4080 - +500 Memory, undervolted Core, 2xCorsair QX120 (push) + 2xInno3D 120mm (pull)
AMD Ryzen 7 7800X3D - NZXT x72
G.SKILL Trident Z @6000MHz CL30 - 2x16GB
Asus Strix X670E-E Gaming
1x500GB Samsung 960 Pro (Windows 11 + 10)
1x2TB Kingston KC3000 (Games)
1x1TB WD Blue SN550 (Programs)
1x1TB Samsung 870 EVO (Programs)
Corsair RM-850X + native 12VHPWR-Cable
Lian Li O11 Vision
Alienware 360 HZ QD-OLED AW2725DF, MSI Optix MAG274QRFDE-QD, BenQ ZOWIE XL2720
Logitech G Pro Wireless Superlight 2
Wooting 60HE
Audeze LCD2-C + FiiO K3
Klipsch RP600-M + Klipsch R-120 SW
My Notebook:
MacBook Pro 16 M1 Pro - 16GB
Proxmox-Cluster:
  • Ryzen 9 3950X, Asus Strix X570E F-Gaming, 4x32GB3200MHz ECC, 2x 512GB NVMe ZFS-Mirror (Boot, Testing-VMs + TrueNAS L2ARC), 2x14TB ZFS-Mirror + 1x3TB (TrueNAS-VM), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i7 8700k delidded undervolted, Gigabyte Z390 UD, 4x16GB 3200MHz, 2x 360GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i5 4670, 3x4GB + 1x8GB 1600MHz, 2x 240GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
Proxmox-Backup-Server:
  • i5 4670, 4x4GB 1600MHz, 2x2TB ZFS-Mirror, 2,5G NIC
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218963
Nah.... high leakage. Which is good for my when I eventually LN the sob.
LLC Auto, v-core auto, 4.1ghz 1.406v. On 2 different boards, same OC results.
Max clock 4.5ghz 1.58v, good enough for a validation. (core reduction)
All core OC stable Intel Burn test 4300mhz.
Overclock did not change before or after the de-lid either.
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13218975
You bothered to delid it?
How much did the temps change?
My Gaming PC:
Lian Li O11 Vision
Wooting 60HE
My Notebook:
Proxmox-Cluster:
https://linustechtips.com/topic/1145704-help-with-overclocking/#findComment-13220065
