For this build, should I buy some 120mm fans on the front as intake in addition to the fan at the back that comes with the case?
https://linustechtips.com/topic/1145447-need-advice-on-cooling/
IMHO, yes.  they don’t have to be super expensive. They’re vertical fans so sleeve bearing is fine.  They’ll want to be high static pressure though.
This case has restricted airflow in front.  This is not necessarily bad.  It does mean that you need the right kind of front fans though.  Specifically ones with high static pressure so they can suck through those far away holes without a problem.
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216497
Do you already have the system? If not, you're probably better off getting a case with better ventilation to begin with.
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216518
It would make it easier. He might need less fans. That looks an awful lot like a >$30 case.  It needs $10 worth of fans to make it work. So $40.  If he can find a case for $40 that doesn’t need fans that would be awesome.  They more often go for $80 though.
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216522
At a minimum I generally prefer 2x 120mm fans as intake and 1x 120mm as exhaust, with proper dust filtration for the intake fans. This ensures good positive airflow and helps keep the system dust free, and your components with a constant supply of cool air.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216525
3 minutes ago, ikeeyigsys5575 said:
do you think then that I should get a phanteks p300
Phanteks p300 seems to have similar front air issues.  If you want front air it’s going to need the same kind of fans.  It’s go some top air though so you might be able to get away without them.
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216530
What you're looking for from a case? The P300 doesn't have great airflow either -- at least not without some particularly good fans.
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216531
so what is the cheapest way to get a decent case with good cooling? I don't want to spend too much on the case
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216533
Imho very possibly what you had the first time.  My rule of thumb is get the cheapest case that has the front panel ports you want, but add to the cost of that case the number of fans you would need to make the airflow work.  your motherboard needs to be taken into account too because it has to have the headers to the front panel you want.  If a case has USBC but you don’t have a USBC header that port is useless
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216539
so will a 140mm fan for intake and 120mm for exhaust be adequate?
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216543
On the first case? Probably not.  The problem is that 140mm has lower static pressure than 120mm quieter, and higher CFM, but lower static pressure.  That case is an old design which is why it’s cheap, and old designs were built for older fans, I.e 120mm
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216546
so should i go with 1 or 2 120mm fans and where should i mount this? TY very much btw :)
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216548
The first case? 2 high cfm 120s in front and the included rear case fan should be fine.
lookimg at pcpartpicker they’re saying arctic P12pwm, which go for $7 a piece, and the case. Is $40 (my pricing assumptions are out of date it seems) so effectively a $54 case with USBa 3.2 in the front panel.
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216560
So I seem to have become committed to finding the cheapest option here.  The deep cool matrexx is the same price but has less obstructed front air which means that single front 140mm might just work, in which case there are numerous fans in the $10 range that would work.  So a savings of $4
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216570
Focus G would be better: https://pcpartpicker.com/product/YhzZxr/fractal-design-focus-g-white-atx-mid-tower-case-fd-ca-focus-wt-w
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216572
so would this be good:
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216582
Fan mentions has no static pressure rating at all (which usually means it’s worthless) the matrexx case seems to have more openings the farther down you go so mounting it low might be good.  Could work though.
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216587
ok. thank you for your help, and i think that is a good fit for me.
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216591
There are a few more options at the very low end (like $25 cases) they tend to have poor front I/o though and they’re side air so they need another fan on the side blowing out.  Side air is kind of a PITA because the fan wire on the side mount fan tends to get in the way of things.  Might be another $5 or $10 to be found but I’m not sure it’s worth it.
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216594
I kind of want a case that has a tempered glass panel
Mo money.  It’s an option.  I personally find them annoying but some insist on them.
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13216599
17 hours ago, ikeeyigsys5575 said:
Ok. Would I still need to buy another fan though?
No, the stock fans should be fine.
Unless I'm mistaken, there's no support for a 140mm in the case.
Case Fan    Corsair CO-8950007 67.43 CFM 140 mm Fan    $4.99 @ Corsair
I wouldn't recommend shipping from Corsair if if you want to save money.
The Matrexx 30 has that but it's not very sleek and considering the lack of a black mask on the edges of the glass.
For that, i'd recommend getting something better like the PS15: https://pcpartpicker.com/product/7PyV3C/silverstone-precision-ps15-microatx-mid-tower-case-sst-ps15b-g
with a TY-147 for front intake: https://pcpartpicker.com/product/qMR48d/thermalright-case-fan-ty147
https://linustechtips.com/topic/1145447-need-advice-on-cooling/#findComment-13218799
