Corsair Vengeance LPX CMK32GX4M2B3200C16
vs
Corsair Vengeance LPX CMK32GX4M2D3200C16
Can't find any differences exept that the First one has been arround since 2015. Anyone have any experience with these to tell me what the difference is? Building my first pc and don't want to get stuck with "bad" Ram.
Motherboard : image.png.c8378d9015844312a12e3eee5801a6e7.png
CPU :
They have the same specs, plug them in, all good.
I use to have different brand with same specs and they work perfectly fine
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
