Are fans on both sides of an aio make it better?
Solved by RadiatingLight,
20 minutes ago, NotABigGamer said:@RadiatingLight I have this aio https://www.amazon.com/240-V2-Technology-Waterblock-Controller/dp/B07QPNP4VP/ref=sr_1_2?keywords=aio+deepcool&qid=1578876908&sr=8-2 that i got for 69.99 and it has fan mounts on the other side but it only included fan screws for one side. Do they sell screws that would allow me to put 2 more fans on the other side?
Screws might be hard to find, but you can just use two screws per fan (on opposite corners) and mount four fans that way.
