Hey everyone! I'm new to the forums(but not LTT) and this is my first post.
So i've been needing to upgrade my power supply for a while now, 1: it doesn't look nice in my new case(NZXT Phantom 530) at all! 2: It likes to make random noises, almost like a quiet screech, and no it's not the fan O.o, it's starting to worry me.
On to the point, i saw the price of the NZXT Hale90V2 on Newegg has dropped quite low, and I was thinking of getting it, but theirs no reviews. It would look nice in my white 530 and its fully modular:)
Should i go ahead and get it? Thanks!
post-53318-0-56503400-1392174796_thumb.j
https://linustechtips.com/topic/114471-new-power-supply/
It looks like an okay power supply...
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/114471-new-power-supply/#findComment-1530235
That PSU is a great choice. What are you going to be powering?
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/114471-new-power-supply/#findComment-1530241
Go for it! :D
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/114471-new-power-supply/#findComment-1530274
As of now, nothing extreme(4670k, GTS 450lol), but in the future 2xGTX 760's in SLI
Oh, alright. Go for it.
https://linustechtips.com/topic/114471-new-power-supply/#findComment-1530278
A good 650w is already plenty for a 760 sli. The psu you chose is good but overkill.
Cheaper option: http://pcpartpicker.com/part/rosewill-power-supply-capstone650m
https://linustechtips.com/topic/114471-new-power-supply/#findComment-1530281
Which PSU would you recommend?
I can't think of any white ones, off top of my head. But it is from NZXT, so you should be able to trust it.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/114471-new-power-supply/#findComment-1530288
Ah nice, doesn't hurt to have extra power xD, but sadly that PSU doesn't fit the white build, but thanks!
https://linustechtips.com/topic/114471-new-power-supply/#findComment-1530316
