The laptop that I have has a 256GB. I also have a Samsung t5 external SSD. Does anyone have USB C to USB C cable that is at a right angle? I want one so that the extra cable is out of my way. USB A to USB C where the USB A is at a  right angle is also fine as well.
Acer Predator Helios 500
8th Gen Intel Core i7 8750H
Nvidia Geforce GTX 1070 8GB (Mobile)
16GB DDR4 SDRAM
1TB Hard Drive
256 GB Solid State Drive
Processor Speed 2.20 GHz
Wireless LAN Standard IEEE 802.11ac
Screen Resolution 1920 × 1080
Operating System: Windows 10 Home
https://linustechtips.com/topic/1144459-right-angle-usb-cable/
This sounds like a job for China channel. It’s terrific for stuff like this.  Banggood, fasttech, alibaba express, etc..
https://linustechtips.com/topic/1144459-right-angle-usb-cable/#findComment-13208458
I found this, where the type c end is right angle : https://www.amazon.com/TRIPP-Cable-Right-Angle-U428-003-CRA/dp/B07JNH2SHX
there's also stuff like this which does usb type c right angle to usb 3 female: https://www.amazon.com/TRIPP-Cable-Right-Angle-U428-06N-F-CRA/dp/B07JNH2JR5/
https://linustechtips.com/topic/1144459-right-angle-usb-cable/#findComment-13208494
