I posted a while back that my 4TB Black Western Digital Hard Drive was making loud noises whenever it was accessed (audio clip attached). I think my product is still in warranty. Would they do something about this? 'Cause everyday I get more concerned using it. I mean, I have these crappy Rosewill fans that came with my PC case, and the friggin' Hard Drive somehow manages to be louder than them!
help.mp3
Just here for some fun.
PC Build 1: Great Ape (Main Rig) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/nKjHGX
CPU: Ryzen 3700X
GPU: ASUS GTX 1070Ti 8GB ROG STRIX
PSU: SeaSonic FOCUS Plus Platinum 750 W
Mobo: MSI MPG B550 GAMING CARBON WIFI
Case: Corsair 4000D
PC Build 2: Piccolo (Emulation/ITX/Transportable) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/tDBdHx
CPU: Intel i5-11400
GPU: EVGA GTX 1060 3GB SC
PSU: EVGA SuperNOVA GM 550 W
Mobo: ASRock Z590M-ITX/ax
Case: Silverstone RVZ03
♪♫ "2-to the-1-to the-1-to the-3 I like good OC and RGB. Configure so much, you wouldn't believe. And I get more blue screen than a Walmart PC" ♪♫
https://linustechtips.com/topic/1144349-hdd-problems/
you have important files inside the hard drive? if yes, then backup those files and RMA that disk.
https://linustechtips.com/topic/1144349-hdd-problems/#findComment-13209444
Yeah, but no problem. I backed 'em up to a smaller HDD that I found lying around.
CPU: Ryzen 3700X
Case: Corsair 4000D
CPU: Intel i5-11400
https://linustechtips.com/topic/1144349-hdd-problems/#findComment-13209628
