hey guys saw the crate computer giveaway and got to thinking is there a case like that on the market that i wouldnt need to mod alot
looking to house a full sized psu, itx motherboard, full sized gpu, and 3.5 in drive while being able to be vesa mounted
its GE (pause) TechNicks
my rig plus everything i have bought for it http://pcpartpicker.com/p/30sNV
https://linustechtips.com/topic/114388-vesa-mount-case/
Probably not. The reason it works with the system you saw is that it has a custom base to help redistribute the weight.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/114388-vesa-mount-case/#findComment-1529149
crate sells the base i assume i could use that
https://linustechtips.com/topic/114388-vesa-mount-case/#findComment-1529151
You could, but I still don't know what case you could use. Your best bet would probably be to contact them and see if they could sell you just a bare-bones system. If not, your only options that I can think of would be to either find some thin and relatively light case and drill some mounting holes in it, or custom build an enclosure.
Desktop: AMD Threadripper 1950X @ 4.1Ghz Enermax 360L  Gigabyte Aorus Extreme   Zotac 1080Ti AMP Extreme  BeQuiet! Dark Base Pro 900  EVGA SuperNova 1000w G2  LG 34GK950f & ASUS PA248Q Klipsch Reference/Audeze Mobius
Synology Wireless AC-2600
Laptop: Alienware 17R5   Intel i7 8750H  Nvidia GTX1080   3840x2160 4k AdobeRGB IGZO Display   32GB DDR4 2133   256GB+1TB NVMe SSD    1TB Seagate SSHD   Killer 1550 Dual-Band Wireless AC
https://linustechtips.com/topic/114388-vesa-mount-case/#findComment-1530709
