hunt on craigslist and other used sites. Your too low for new pricing. Id look for a used prebuild dell or hp or simmilar, you can probably get one with a i5 or i3 for that price.
Also try using the igpu in those, it may be faster than the 710.
https://linustechtips.com/topic/1143393-uber-cheap-build-help/#findComment-13199839
What he said...craigslist is a goldmine if you live near a large city.
https://linustechtips.com/topic/1143393-uber-cheap-build-help/#findComment-13199845
You're not going to get much for $100 unless you're patient. The GT 710 isn't a viable option for most modern games, I wouldn't bother with it unless you plan on playing undemanding titles. I would check your local classifieds until you find a system that fits your budget. If nothing else, a Dell Optiplex will run some games until you can upgrade to a dedicated graphics card.
"Make sense? Oh, what fun is there in making sense?"
-Discord
https://linustechtips.com/topic/1143393-uber-cheap-build-help/#findComment-13200243
