Hello, I am having trouble with my RAM always being high, I've done lots of research and done a lot of things on the internet. On my Operating System only it runs at around 50%
Here you can see i am only running Arma and Chrome and receiving 80%+
https://prnt.sc/qkl63l
I have 16GB of RAM and never had a problem, Is this a realistic problem or not?
https://linustechtips.com/topic/1143029-memory-problems/
you didnt list them out in decreasing order of RAM usage...
Desktop benching:
https://linustechtips.com/topic/1143029-memory-problems/#findComment-13196808
5 minutes ago, Oli1549 said:
My Bad, Here you go. http://prntscr.com/qklai7
Quote people when you reply so that they get a notification.
Seems like a bunch of programs are using a few hundred MB of RAM and those programs add up quickly. I would start by closing what you don't need open all the time.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1143029-memory-problems/#findComment-13196828
You really think that is the reason? i've never had a problem before!
https://linustechtips.com/topic/1143029-memory-problems/#findComment-13196830
If you add up just the numbers visible in your screenshot, you're already at 8 GB, so 50%. If you switch to the performance tab, you'll probably see that Windows also uses some RAM as cache (which isn't bad, that memory will be made available when needed).
https://linustechtips.com/topic/1143029-memory-problems/#findComment-13196844
Ok, I have never looked at that cache before, the cache is completely reserved then? never used by other programs? I have just put a order in for 2x16gb ram so that should cover it
https://linustechtips.com/topic/1143029-memory-problems/#findComment-13196850
No, that is pretty much the opposite of what I said.
The cache is used to speed up the startup of programs. Windows will make that memory available to apps when they need it (i.e. it will drop the cache so the memory can be used by apps). Think of the cache as "unused" in a way, because Windows will only keep that memory reserved so long as applications do not require that additional memory.
Instead of ordering more memory, I'd try to go with @kelvinhall05's advice. Close stuff you're not actively using. Do you need both TS and Discord open at the same time? What about Steam, Arma 3 Launcher, Malwarebytes? That's probably .5–1 GB you could get rid of right there.
https://linustechtips.com/topic/1143029-memory-problems/#findComment-13196869
My thoughts were that i had a memory leak, if im simply using all of my RAM im more than happy to expand, i arent one that wants to worry about closing apps because of ram usage, i just have the leave the 50 chrome tabs open! Shouldn't have any more problems with the upgrade though!?
https://linustechtips.com/topic/1143029-memory-problems/#findComment-13196873
A memory leak is a bug in a specific program. You'd have to see the program use more and more memory until that one program uses all of it. That happens when a program reserves memory "forgets about it" and then reserves more, never freeing the memory it reserved. Unless you can observe such behavior in one of the programs you're using, it's not a memory leak.
I mean, it's your money ? If you want to upgrade, go for it.
https://linustechtips.com/topic/1143029-memory-problems/#findComment-13196879
Yeah exactly why i felt it was a leak, because it has got worse and worse, ive never had any issues with 16gb of ram. Only recently started having more and more problems.
https://linustechtips.com/topic/1143029-memory-problems/#findComment-13196881
Like I said in that case you'd have to see one program use all of it and its use would have to go up over time until your system grinds to a halt. Some time ago some background indexing tool that I had installed on Linux had a memory leak. It took about 1-2 hours for this one program to use all of my memory. As soon as it started to eat up swap the system would essentially come to a full stop until it was rebooted. It took several minutes just to open a task manager to see what was going on.
In other words I'm pretty sure what you're seeing is not a memory leak. Having a ton of apps open that all use a little bit of memory is not a memory leak.
https://linustechtips.com/topic/1143029-memory-problems/#findComment-13196906
it's the web browsers's fault. my opera shows up in task manager 26 times, i mean as 26 opera processes and make my pc run slower. it helps to install the 32 bit version.
https://linustechtips.com/topic/1143029-memory-problems/#findComment-13203908
