80mm ARGB CPU/PWM Fan?
Jay Deah
I've just done a new build in a Lancool 2 with all the lighting running off the case fan controller which is 3 pin A-RGB.
Thinking of swapping the 80mm Fan on the CPU cooler (Lenovo OEM Cooler) with an ARGB one but cant seem to find any one amazon. Anyone know of any?
Alternatively i could swap the cooler with a hyper212 i have spare and then use a standard 120mm ARGB fan but want to see what my 80mm options are first.
Thanks in Advance
Thanks in Advance
I think the swapping the cooler will be much better option , not only cos it’ll keep temps lower but also to find 80mm rgb fan will be quite hard (specially decent one)
   @Whiro tag or quote will do the trick
i5 3570K @ 4.7Ghz  |  AsRock Fatal1ty Z77 Performance  |  Corsair Vengeance 16GB 1600MHz  |  ASUS Strix GTX 970 OC  |  Phanteks P400S TG  (mesh panel) |  EVGA 500W1  |  Storage: Corsair 60GB SSD (boot), Gigabyte 120GB SSD, WD 2Tb HDD | Cooling: Custom loop
                EKWB EK-XRES 140 Revo D5 RGB PWM
                EKWB EK Supremacy Evo , naked die
                EKWB EK Thermosphere
                EKWB EK CoolStream PE 360
                EKWB EK Coolstream SE 120
                EKWB EK Vardar 120s  x6
                EKWB EK STC Classic 10/16  x10
                EKWB EK DuraClear Tubing 16/10
                EKWB EK CryoFuel Acid Green
Laptop: Gigabyte G5-KC | i5 10500H | RTX 3060
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
you know, you made such a good point that i went ahead and swapped the cooler for a 212 LED Turbo i had spare. wow what a differnce, wasnt till i looked at the original cooler properly i realised how weak it was. it's now keeping a E3-1275v6 (similar to an i7-7700) at <60degrees without the fans ramping up above 800rpm! :)
before
after
I’m glad it helped ? also next time try to quote me or tag , not always I see ppl responding
                                          WHIRO
