Hey guys what do you think about this build?/What would you change?
MSI GeForce RTX 2070 Super Gaming X Trio 8GB GDDR6
Intel® Core™ i9-9900K
Gigabyte Z390 Aorus Pro
Trident Z RGB 16GB (2x8GB) DDR4-3600 MHz CL16
Samsung 970 EVO Plus 500GB SSD NVMe M.2
Corsair TX650M 650W 80 Plus Gold Semi Modular
Corsair Hydro Series H150i Pro RGB
Lian Li PC-O11DX Dynamic
https://linustechtips.com/topic/1141896-nice-build-for-gamingstreaming/
Gaming only? If yes, i'd go for either 8700k + 2070super or 9900k + 2080 s/ti. No much point in 9900k + 2070s
Do you already have the mobo?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
Badly balanced. You could've went with Ryzen 7 3700x, cheaper cooler+mobo and higher end GPU.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
Just now, Fubaralle said:
I dont have the mobo yet.
Well, I was gonna say go with AMD 3800X / 3900X if you game at 1440p or higher.
9 minutes ago, Fubaralle said:
I chose the i9-9900k  cause I have a friend of mine that buys directly from globaldata(portuguese shop) suplier and can get me a 365 euros price.
He can't get a discount on AMD?  But if he can't that is still awesome.
EVGA boards are a pretty safe bet for overclocking
if the RX 5700 XT is a lot cheaper probably just go for that, has 90% the same performance.
