So, this is probably the first time I've ever asked a stupid question.... but...
Say I happen to have a 360 Radiator in pull Config(Custom Loop) and I decide to buy an AIO 120mm Cooler for a particular component that could only be place at the front of the case where the 360Rad is? Would there be an issue installing said 120Rad(Also in pull config) onto the 360? (Also yea you can't put a screw through a radiator but I have my own dodgy way of doing it without damaging da rad.)
Not even gon lie, I'm quite lazy which is why I don't want to undo the current loop and deal with bending the tubes etc to cool my Component...
UPDATE: I could probably cut the tube in the AIO and make it longer to help install the 120rad to the back, but ehhhh, too much effort.
https://linustechtips.com/topic/1141834-radiator-help/
Yes, there are instances where they show having (for example) Fans/Radiator/Fans/Radiator/Fans all mounted as a big sandwhich (2x240mm rads with 6 total 120mm fans) that actually don't help temps but its doable.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1141834-radiator-help/#findComment-13186592
yeah you could do this no problem.
only issue would probably be that the 120mm rad gets hot air from the 360, so cooling performance might not be ideal.
https://linustechtips.com/topic/1141834-radiator-help/#findComment-13186593
It's not going to perform very well since you are essentially stacking radiators which can be done but not recommended.
http://www.xtremesystems.org/forums/showthread.php?220874-More-Radiator-Sandwich-testing
https://linustechtips.com/topic/1141834-radiator-help/#findComment-13186594
1 hour ago, Aloosh709 said:
That was a quick reply. As long as its doable without to much of an issue, I'm happy. Thanks for your replies peoples.
Unless you have the correct length screws/threads etc - don't forget zip ties exist and work well for this kind of application.  Black ones blend in just fine.
https://linustechtips.com/topic/1141834-radiator-help/#findComment-13186782
