5 minutes ago, Founders said:
Twist it very carefully until it breaks loose, this is very normal with AMD's PGA sockets.
It was normal with Intel when they still used PGA
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1141648-cpu-stuck-to-aio/#findComment-13185180
Yeah you have to be a little more careful with PGA CPUs. Reinstall the CPU and see if the system still works fine. I've heard of issues following such as failure to POST, BSOD in windows and unstable overclocks that were previously stable. If everything seems fine'n'dandy you got away with one.
https://linustechtips.com/topic/1141648-cpu-stuck-to-aio/#findComment-13185195
9 minutes ago, Oneofseven said:
I've never seen this before, I went to remove my AIO to upgrade to a Ryzen 5 3600.
With my AIO came out my CPU and it appears to be glued to the contact. It popped right out of the socket with the locking arm down.
What do I do??
You should never pull that hard to be able to pop the CPU out with the retention arm down. If its that hard, always twist the heatsink back and forth before pulling up.
But now its out, get some pliers to hold the cpu firmly, or put it in a vice and twist the cooler to break the seal. You should be able to pull it off, if not use a large flathead to leverage it off.
Considering how new the CPU is, are you sure you used thermal paste and not thermal adhesive?
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1141648-cpu-stuck-to-aio/#findComment-13185202
What do I do??
What you can do is not to start new threads if people already answered your question at first place.
And like I said before check for bent pins
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1141648-cpu-stuck-to-aio/#findComment-13185242
