My b450 tomahawk max will not flash the BIOS. The LED next to the flash bios button ones not even come on When the usb is plugged in. Is it bricked or defective etc.?
Specs:
Ryzen 5 3600
1080 ti
B450 tomahawk max
Corsair CMK8GX4M2A2666C16 Vengeance LPX 8gb (4x2) 2666 mhz
Corsair cx 650
https://linustechtips.com/topic/1141585-mobo-wont-flash/
5 hours ago, MIAOWEE said:
Im not sure, the rgb fands etc work
well then care to fill us in on the situation at all then?
like did the board ever work at any point... is this a newly built machine.....why are you updating the bios.... what components are in use.......
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13185483
The machine never has POSTed. The reason why im flashing is because the ez debug light on my mobo is stuck at the CPU LED. I'll update the description with my specs
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13186631
At this point I might just RMA it and buy another max board
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13186653
It’s weird cos Tomahawk Max have support of Ryzen 3rd gen out of the box. Did you tried any troubleshooting?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13186736
2 minutes ago, MIAOWEE said:
Yes, I tried taking it out of the band booting with 1 stick of ram etc. Nothing
Clear cmos and try again
                                          WHIRO
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13189526
17 minutes ago, MIAOWEE said:
I have now RMAed it and have now gotten a msi b450 gaming plus max. Finger crossed that it work
It Apparently isnt the mobo cos the CPU is still not detected. Its probably not cpu either cos it is the second one. The ram is fine I think cos the ez debug dram lights up if I take it out. Help!
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13189593
Silly question, do you have dedicated gpu?
                                          WHIRO
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13189641
Yes and a 3400g that I borrowed from a friend. Tried both.
Ok lets start from beginning. Correct me if I’m wrong. You got the Tomahawk Max board, you tried to flash the new bios which didn’t work and pc was posting. Since then you rma board get the new one and still no post.
Is there any signs of life in your system? Fans spinning etc? You tried clearing cmos and this didn’t work as well. What else did you tried?
                                          WHIRO
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13189690
Yes everything turns on and fans spin etc. But the CPU LED is constantly on. I have tried out of the box, 1 stick of ram new cpu, 3 different mobos. Amazon must think im a dumbass.
Edited by MIAOWEE
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13189725
Ok I’ll list all the things which I would do on your place.
Remove the mobo from the case and test it on the box, re-plug all the cables to be sure they connected properly (both ends if you have modular psu), make sure cpu cooler is installed properly and making good contact with cpu, reset cmos, replace battery on board (believe I heard it helps sometimes).
                                          WHIRO
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13189777
Ok will do asap
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13189787
K so Did this tried to flash bios, worked for a bit and now is stuck at solid red light
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13190246
Why the hell you trying to flash the bios if its working without doing that?
Other thing is are you sure you using right bios and doing everything correctly??
                                          WHIRO
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13190340
Well at least It isnt bricked. And yes, I followed the msi tutorial. Honestly, im not sure what to do anymore. The CPU LED is still on and my brain is confused so im just gonna call it a day and look at this tomoz
https://linustechtips.com/topic/1141585-mobo-wont-flash/#findComment-13190620
