Can i connect direcly to switch with LAN Cable???
7 minutes ago, MGI said:pretty much empty
That is to be expected, the dialog just tells you that it is using auto-configuration not the current IP it received. Open the command line and enter "ipconfig", see what values you get there. Connect your AP again and have a look at its settings or status page. Take note of the IP, netmask, primary router/default gateway and DNS it receives. Compare that to your PC, it should get the same settings (with the possible exception being the IP, which should be in the same range).
It also possible the managed switch is blocking you due to some security settings.
~edit: What Windows version is that? On Windows 10 you can right click on network, then click on "Open Network & Internet settings", then click on "View your network properties", that should give you all the information you need.
