Alright, so I just build my new PC about a month ago now and I have had several crashes and BSODs that all contain different errors. I've been everywhere to troubleshoot these issues but alas they still exist.
I have a:
Ryzen 5 2600x
Gigabyte B450m Motherboard
16gb Corsair Vengeance RGB Pro 3200
Gigabyte RTX 2060 Super
Corsair MP300 NVME SSD, WD Blue 1TB HDD, and a Seagate 2TB HDD
I don't even know where to begin with the issues that I am having, if I am playing a game sometimes it will just end and not give an error message or the PC will blue screen and give a different message everytime. I have tried to check my disk several times and Windows doesn't recognize any error with that, the only thing that I've changed in the BIOS is enabling XMP, turning on AMD-V and changing the fan speeds of my fans. I recently just got RDR2 and for the first couple of days everything was going great but then I noticed that I was only getting 30FPS on high settings, which to my knowledge shouldn't be happening considering the hardware. I have also had some issues with my peripherals connecting and disconnecting randomly, I've noticed that they would reset and then just reconnect and make that annoying windows sound every damn time. I'm not sure if this makes a difference but I have like every Corsair peripheral and I'm not sure if they are interfering with the computer in any way. I have reseeded my memory and GPU a couple of times to check if that was the issue but it still continued. My temperatures are decent sitting around 75-80c on both the CPU and GPU. I would appreciate any form of help at all thank you. I have also included my DXDIAG, and MSINFO32 files to help with the diagnosis.
Also I'm new to forum discussions so if this topic is meant to go somewhere else please inform me thank you.
DxDiag.txt msinfo.txt
https://linustechtips.com/topic/1140092-pc-crashingbsod-ing-need-help-please/
