Hey guys, I got this monitor on black friday for a screaming deal, and I absolutely love it, but I've had a few issues.
1. It's a 144hz panel, but I cannot get it to display past 120hz. I even went so far as to buy a really nice DP 1.4 cable off amazon, still no dice. DP 1.4 is selected in my OSD.
2. When I plugged in the new DP cable, today I got a popup saying "Caution, only use provided input cables" or something to that effect. I can't see it being possible, but do I risk anything running a not supplied DP cable?
thanks for any help.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1139700-lg-34gk950f-issues/
Heh.  “ really nice” and “off Amazon” don’t always go in the same sentence very well.  “Fulfilled by Amazon” and “Amazon” are different things.  The monitor apparently doesn’t like your cable for some reason.
https://linustechtips.com/topic/1139700-lg-34gk950f-issues/#findComment-13170035
So it’s most likely a just a cable issue?
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1139700-lg-34gk950f-issues/#findComment-13170131
Dunno.  The problem with computers is there’s always this big long chain of things and the device only functions if they all work.  Cable could possibly be on the list though.  Was it “amazon” or “fulfilled by amazon”?  The fulfilled thing means some no name contractor payed to get his stuff on their website.  Less quality control.
https://linustechtips.com/topic/1139700-lg-34gk950f-issues/#findComment-13170211
I feel like i know the answer to this, but my LG 34GK950F is telling me to always use the supplied input cable. Can my aftermarket one cause damage?
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1139700-lg-34gk950f-issues/#findComment-13170479
https://www.amazon.ca/gp/product/B07P85R71F/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
this is the cable.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1139700-lg-34gk950f-issues/#findComment-13170480
1 hour ago, yaboistar said:
plugging in any cable that the manufacturer has not sold to you for a highly marked up price will cause your product to instantly explode
/s
no, it will be fine, they include that marketing wank as a "gotcha" for squeaking out of their own warranty but also to make a buck on selling cables to all the old people they've scared into not using any other cable but the supreme LG branded ultra uber-cable
if the cable you currently have makes you concerned, amazonbasics are a pretty solid way of getting inexpensive cables that are manufactured properly
Thanks. It's a decent looking cable. I'll probably be replacing it soon. The DP that came with my monitor doesn't let me run 144hz, so I bought a DP 1.4 cable on amazon, it still won't run at 144hz, so maybe I'll try a nice one from Bestbuy or something too.
Because fuck money, ya know what I mean? I enjoy paying over 1k for a monitor then spending $50 on a charade of cables getting it to work.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1139700-lg-34gk950f-issues/#findComment-13170551
5 minutes ago, Statik said:
Says sold by atevon and fulfilled by Amazon.  So you didn’t really buy from amazon you bought from
https://www.amazon.ca/sp?_encoding=UTF8&asin=B07P85R71F&isAmazonFulfilled=1&isCBA=&marketplaceID=A2EUQ1WTGCTBG2&orderID=&seller=A2REBULWX98LHD&tab=home&vasStoreID=
they’ve got decent ratings and have sold many things.
https://linustechtips.com/topic/1139700-lg-34gk950f-issues/#findComment-13170552
Interesting. Quite confused as to why it won't work.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1139700-lg-34gk950f-issues/#findComment-13170554
should run 144hz. Try reseting ur display drivers ( Win+Ctrl+Shift+B ) see if it picks it up as 144hz then.
Are u sure u got the 34GK950F-B and not the 34GK950G-B  ??
The G-B is Gsync and apparently runs at 120hz native.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1139700-lg-34gk950f-issues/#findComment-13170829
Im 100% sure. It has free sync enabled. Not Gsync. And resetting drivers didn’t help unfortunately
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1139700-lg-34gk950f-issues/#findComment-13170853
