upgrade I need help upgrading my PC
Solved by brob,
You will have to flash the BIOS before changing the cpu.
PSU is optional upgrade. If budget allows you could consider a Corsair TX550M instead.
CPU: Intel Core i5-9400 2.9 GHz 6-Core Processor ($184.99 @ Best Buy)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive ($109.99 @ Amazon)
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply ($69.98 @ Amazon)
Total: $364.96
Generated by PCPartPicker 2019-12-29 14:09 EST-0500
