Microphone volume too low
I recently bought the Corsair Void Pro headset. While testing the microphone, I noticed its volume is extremely low. For example, while using discord, my friends have to boost my volume up to 200% and they say it's still low. This didn't happen with any of my previous headsets. I checked the volumes in the mic properties and it's set all the way up to 100%, and there is no boost option. What should I do?
https://linustechtips.com/topic/1138569-microphone-volume-too-low/
I had the same issue when ibought my pair of HyperX cloud 2's a headset with nutorious low input. The way that iresolved my issue was to download and setup Equalizer APO and set a fixed amount of gain on the microphone. This is alsoreally nice to be able to put some EQ setting on your headset to get better sound aswell.
(Put EQ setting on your mic aswell to make your friends ears hurt XD)
Main PC:
CPU: Intel i9 - 13900k, Cooler: Arctic Liquid Freezer II 420mm
GPU: PowerColor Red Devil RX 6900 XT 16GB,
Motherboard: Gigabyte Z690 Aorus Elite,
Ram:
G.Skill Trident Z neo C16 3600Mhz 32GB,
PSU: Corsair HX1000i 80+ Platinum.
SSD: Samsung 970 EVO Plus 1TB
Case: Fractal Design Meshify 2 XL
Gear
Mouse: Logitech G Pro
Keyboard: Iqunix F97 Hitchhiker
Headphones: Philips Fidelio X2HR
Speakers: Yamaha HS7
Mic: 512 Audio skylight
Screens: LG 27GL850 & Samsung 34" Odyssey G5 Samsung
