37 minutes ago, jakeslayer9091 said:
PCPartPicker Part List: https://pcpartpicker.com/list/q8ZFPn
CPU: AMD Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($77.98 @ Amazon)
CPU Cooler: Deepcool GAMMAXX GTE 56.5 CFM CPU Cooler  ($29.89 @ SuperBiiz)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard  ($69.98 @ Amazon)
Memory: Patriot Viper 4 8 GB (2 x 4 GB) DDR4-3000 Memory  ($34.99 @ Amazon)
Storage: Kingston A400 480 GB 2.5" Solid State Drive  ($52.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 1660 6 GB GAMING OC Video Card  ($249.99 @ Walmart)
Case: Rosewill CULLINAN ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Thermaltake Smart 500 W 80+ Certified ATX Power Supply  ($44.99 @ Amazon)
Total: $610.80
Generated by PCPartPicker 2019-12-26 14:57 EST-0500
I chose the AMD ryzen 3 2200G because I'm getting a custom Cooler which Will maximize my CPU Overclocking which is great, I got 8GB for now since I'll prob upgrade to 16 GB later and for the card I chose Gigabyte 1660 6GB OC since I'm going to overclock everything to it's max, and it comes to a cheap 600$, I watched a benchmark video for the CPU&GPU w/out overclocking and it could run csgo (max) at 200 and gta (ultra) at like 90, and way more games, and I'm also gonna go on pcpartpicker again and try and get a cheaper 500$ build
Actually i think I'm sticking with the 600$
My custom loop 5000$ PC:
 CPU: Intel i7 9900k Motherboard: Asus Prime Z390-A RAM: 32GB (x4 8GB Modules) Corsair Dominator VideoCard: Asus Nvidia 2080ti HDD/SSD: 1TB M2 Samsung EVO 970 Case: LianLi O11 Dynamic (White) Radiator: x1 Corsair Hydro X Series XR5 360 Fans: x6 Corsair LL120 RGB Tubing: Thermaltake PETG ID: 13mm OD: 16mm Fittings: Bitspower Throughout Waterblocks: CPU: EK-Velocity RGB (Nickel+Plexi) VideoCard: EK-Vector RTX 2080ti w/ Nickel Backplate (Nickel+Plexi) Reservoir: Bitspower Touchaqua Sedna Front Plate Options: Corsair Commander Pro, Corsair RGB Controller, Custom Sleeved Cables for CPU, ATX and PCI-E
6 hours ago, Sumolizer said:
I think that is due to a old driver ( The 5000 and 6000 series don't get driver updates now)
The last one is from maybe Feb 2016
so basically rip , i need to build a new pc which I'm going to soon
This build looks alright, only thing I would change is psu. Try not to cheap out on that and get at least something like Corsair CX
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
Yea I'll switch it out with the semi modular corsair cxm 550W and the CX is a bit too expensive tho so I'll stick with the CXM
Look for something from Tier B+ at least.
                                          WHIRO
Alright fine Im chosing the B+ Corsair cx 550w
