Yo guys, so my gpu has a max Core clock of 775 MHz and and Memory Clock of like 1000 MHz and for some reason, The core clock is always at 300-400 MHz, and the memory clock is at 150-300 MHz (Even when gaming), I have no bottleneck, and the GPU or CPU is not overheating, it stays at 50 degrees, how do i Fix this, I have so many fps drops and I lag so much.
Specs are:
cpu: i7 4500u
gpu: amd radeon hd 8800
ram: 18g
i use msi afterburner
My custom loop 5000$ PC:
 CPU: Intel i7 9900k Motherboard: Asus Prime Z390-A RAM: 32GB (x4 8GB Modules) Corsair Dominator VideoCard: Asus Nvidia 2080ti HDD/SSD: 1TB M2 Samsung EVO 970 Case: LianLi O11 Dynamic (White) Radiator: x1 Corsair Hydro X Series XR5 360 Fans: x6 Corsair LL120 RGB Tubing: Thermaltake PETG ID: 13mm OD: 16mm Fittings: Bitspower Throughout Waterblocks: CPU: EK-Velocity RGB (Nickel+Plexi) VideoCard: EK-Vector RTX 2080ti w/ Nickel Backplate (Nickel+Plexi) Reservoir: Bitspower Touchaqua Sedna Front Plate Options: Corsair Commander Pro, Corsair RGB Controller, Custom Sleeved Cables for CPU, ATX and PCI-E
https://linustechtips.com/topic/1137765-gpu-not-using-max-potential/
Maybe it's time for an upgrade?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
any other solutions?
Cuz i dont get cash to upgrade
It is a it is a 6 year old GPU.....
55 minutes ago, Sir0Tek said:
Isn't it due to power saving? Is it a laptop?
yea n power saving is off
Yea but like there has to be another way, im too poor, if im gonna upgrade, I'll prob upgrade in like 5 months
17 minutes ago, Sir0Tek said:
You do game while power is plugged in? Did you check the settings in the Ati-panel (Catalyst, I guess)?
yea while plugged in, and how do I get to the catalyst settings thing? dont know what that is
10 minutes ago, Sir0Tek said:
Part of the amd software, it came with the driver you're probably using. Or isn't it on Windows but Linux and you're using Mesa?
I'll check for it in the software hold on
I tried looking everywhere,cant find it, u know anything bout where it is
wait nvm i got it :/ ?‍♂️ I didnt have catalyst downloaded for some reason, Ima download it rn
I checked the settings, everythings fine, what am i supposed to do now?
Go to windows power plan and make sure it’s in performance mode, also check there in advance settings what’s the cpu and gpu set as, should be 100%
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
yea, it's at performance mode, and cpu is 100% and gpu is at "Maximum Performance", I dont have percentage option for the gpu
Just to be on the safe side DDU all drivers in safe mode, than download new drivers. Also in device manager make sure all drivers for cpu and gpu are up to date. Same as windows
                                          WHIRO
aight i unistalled them all with ddu, reinstalled them, checked the settings made sure power saving was off and all, ima open a game and hopefully it works
My best advice when you can't afford a upgrade is to backup all your files, do a clean windows install to clear out whatever mess has built up in regards to backround processes, registry errors etc, then once reinstalled do everything you can to eliminate backround processes you don't need (turn off backround apps in privacy settings, maybe even get 'Shut Up Windows 10' and aggressively turn off stuff you don't use), the average frame-rates usually stay similar but you can see massive increases in frame minimums (1% and 0.1% lows), reduced stuttering etc, which honestly is the most irritating thing on older systems
Reinstall OS or not, going as far as you can to just clean up backround processes goes a long way
4 minutes ago, Otto_iii said:
My best advice when you can't afford a upgrade is to backup all your files, do a clean windows install to clear out whatever mess has built up in regards to backround processes, registry errors etc, then once reinstalled do everything you can to eliminate backround processes you don't need (turn off backround apps in privacy settings, maybe even get 'Shut Up Windows 10' and aggressively turn off stuff you don't use), the frame-rates usually stay the same but you can see massive increases in frame minimums (1% and 0.1% lows)
I did that a couple days ago and it didn't work which is why i came here, and I'm too lazy to do it alll again, since it probably wont work, I don't even think it has to do with the mess, or background processes etc., prob something else, so here i am trying everthing
Didn't work darn it, what am i supposed to do now
aight i cant fix it, what gpu do you recommend? something that's cheap and  can get me playable fps like maybe 30-60 on medium or high settings
2 minutes ago, Sir0Tek said:
Did you try without MSI Afterburner?
What games exactly are you playing and it is the 8800m series, isn't it? Which one exactly?
what do you mean try it without msi afterburner?, and yeah its the 8870m n im playing games like gta, csgo, cod, etc.
