Pc won't post??
Go to solution Solved by TimTim,
16 hours ago, minibois said:
It sounds exactly like a Mobo problem (in theory it could also be the ram or CPU, but that is less likely).
turns out it was the ram both sticks were dead
Do you know if the BIOS was Ryzen 2000 compatible? Does it say anything about that on the motherboard box?
If not, I would suggest either trying to update it, or rather just return it and get a decent B450 board.
https://linustechtips.com/topic/1137291-pc-wont-post/#findComment-13151956
it says ryzen 3000 ready on the box
https://linustechtips.com/topic/1137291-pc-wont-post/#findComment-13151958
and it says the 2400g is compatible on gigabytes website
https://linustechtips.com/topic/1137291-pc-wont-post/#findComment-13151961
Are all the cables plugged in properly? Specifically the 24 pin and 8 pin cables.
What happens when you try to turn it on? Any LEDs turning on? Have you tried shorting the power pins with a screwdriver?
https://linustechtips.com/topic/1137291-pc-wont-post/#findComment-13151966
I've tried unplugging everything and plugging it back in. i reseated the cpu and ram. when i press the power button all the fans spin up but the monitor stays black
https://linustechtips.com/topic/1137291-pc-wont-post/#findComment-13151973
Could you ensure your monitor is on the right input? Or better yet - try another monitor (or TV) just in case your PC and the monitor don't play well together.
If there is a dedicated videocard in the system, be sure to plug in those ports
https://linustechtips.com/topic/1137291-pc-wont-post/#findComment-13151977
ive used two different monitors both using a dvi and vga cable. there isnt a dedicated gpu installed
https://linustechtips.com/topic/1137291-pc-wont-post/#findComment-13151984
It almost sounds like you got a DOA motherboard in this case.
As a last resort, try booting with as little connected as possible. So no disks connected and such.
https://linustechtips.com/topic/1137291-pc-wont-post/#findComment-13151993
i tried booting with no disks and with only one ram stick and its the same problem and the usb ports still dont work. so you think half of the mobo is just dead?
https://linustechtips.com/topic/1137291-pc-wont-post/#findComment-13152009
https://linustechtips.com/topic/1137291-pc-wont-post/#findComment-13152583
