Hey guys just done building my Stream pc specs as bleow
B450 Tomahawk mobo
Ryzen 7 2700x
Team Group xcalibur 3600mhz Ram
gtx 1060ti
the problem im having is my ram will not go past 3000mhz, i have Tried everything
 enabling xmp does nothing
 i have manually set Voltage and timings and nothing, i have used the amd dram Calc and nothing, it always Reboots and Reverts all my settings back to 2400mhz
Update to Latest bios. anyone able to help me out?
and yes have tired every single Mhz settings up to 3600 and it just reverts everything bac to 2400mhz
https://linustechtips.com/topic/1136959-b450-tomahawk-memory-problem/
Zen+ CPUs can get as bad as only running 3000MHz RAM. Blame the CPU.
Desktop benching:
6 minutes ago, Cybersamurai said:
i have had 2 diffrent Cpus in this sytem A 3200g and a 2700x and both did the same thing
3200G is still Zen+, just like the 2700X.
2 minutes ago, Cybersamurai said:
ITs rather frustrating that is list that they both can handle up to 3400 OC but wont boot past 3000
With a CPU that doesnt lose the silicon lottery, yes. You clearly lost it
You could try updating the BIOS
Desktop benching:
i have updated the bios :( and To lose it two Times what the Chances that both my Cpus wont do it?  lamee
1 hour ago, Beowulff83 said:
Have you tried reaching out to msi?  I had issues with my ryzen 1st gen and asrock support was able to help me get my ram up to 3000mhz at the time.  It may be worth emailing them with the details.
i havent yet i wanted to exhuast my options, i have seen people using 3400 mhz no problem on B450. i hit 3000 just fine and it runs great but nothing past that
