3 minutes ago, JRidley09 said:
I need to find what cpu coolers are compatible with me Xeon e3-1230 cpu, the socket listed is lga 1155 and I've bought multiple coolers that are compatible with that socket but none seem to fit
What motherboard
8 minutes ago, Streetguru said:
What motherboard
Not a retail one but pulled from a hp z210. Motherboard already has a proprietary 18pin power socket so wouldnt be much of  surprise to find a proprietary cooler as well
Well you can always try zip ties, but more than likely it may be a lost cause.
Is that the mobo?? If so for me it looks like it’s using AMD type of spacing and mounting mechanism
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
Yes indeed that is the mobo. Honestly that's what I'm thinking at this point, none of the the lga 1155 coolers come close to fitting
                                          WHIRO
I don't think think it's LGA, could be some other like BGA. That looks like rectangular shape vs LGA1155 being square.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
