This should give you an idea of what it supports:
Quote
AMD Socket AM3+ CPUs
List of supported CPU's:
https://www.gigabyte.com/Motherboard/GA-78LMT-USB3-rev-60/support#support-cpu
THe FX 6300 is usually a decent value, for AM3+.
But uhh... This is super awkward, but it's not really a good idea to get a motherboard while not having a plan for CPU (and RAM). A budget AM4 board and a second hand 2200G and some dual channel DDR4 would probably work a lot better.
https://linustechtips.com/topic/1135047-help-pleas/#findComment-13133454
What im asking is will it or will it not work
https://linustechtips.com/topic/1135047-help-pleas/#findComment-13133459
wont work
https://linustechtips.com/topic/1135047-help-pleas/#findComment-13133460
These are the chipsets that work with (Motherboards)
For 2th gen CPU:
For 2nd and 3rd gen:
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1135047-help-pleas/#findComment-13133468
Just now, Reginald Bonemeal said:
What would happen if i tried to put an lga 1155 cpu in it
you can't.
CPU (illustrative only):
Intel-Core2-Quad-Processor-QX6700-CPU-LGA775-Desktop-CPU-CPU-LGA-775-100-goed-werkt-Desktop.jpg
Board:
The board expects a CPU with pins, the CPU expects a board with pins. Not compatible, won't work, you can't even install it.
https://linustechtips.com/topic/1135047-help-pleas/#findComment-13133469
