E-ATX Horizontal Case
Go to solution Solved by Zando_,
Thermaltake has cases that are just a Tower 900, but smaller (link), still can run dual 360mm rads. Other than that there's some old Raven cases like the one @MEC-777 is modding (but from my quick look into them they don't have good rad support stock), and that's pretty much it other than looking into full custom fab AFAIK.
Hi all,
Anyone know of a good PC case that can be placed horizontally (like the good old IBM PC/2s) that also supports up to 2 360mm Rads and 2 reservoirs?
Trying to build a PC using my existing hardware, but changing the case. I have an Asus ROG ZE running the Ryzen 1950X and a GTX 1080 Ti, both water cooled with their own loops in a Thermaltake Tower 900 with 2 200 ml reservoir/pump combos.
The tower 900 is a monster that's taking too much floor space and I want to be able to put the machine on my tabletop. Newegg and Amazon are showing me some options (Sepcifically, the Lian Li PS-O7SX and the CoolerMaster HAF XB EVO), but I don't think they will fit 2 360mm rads with 2 reservoirs and cooling loops.
Any help would be much appreciated.
https://linustechtips.com/topic/1134230-e-atx-horizontal-case/
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1134230-e-atx-horizontal-case/#findComment-13127609
Technically every PC case can be placed horizontally.
https://linustechtips.com/topic/1134230-e-atx-horizontal-case/#findComment-13127617
Thanks @Zando Bob. I figured that was the case, but wanted to confirm.
Guess I'm going back to air cooling my graphics card. Honestly the cooling performance is not that bad with the stock coolers (It's the EVGA GeForce GTX 1080Ti FTW3)
https://linustechtips.com/topic/1134230-e-atx-horizontal-case/#findComment-13127623
26 minutes ago, greatguitartist said:
The tower 900 strongly disagrees with you.
https://linustechtips.com/topic/1134230-e-atx-horizontal-case/#findComment-13127655
