Alright so i need some help here because i bought a cheap mans gaming laptop the dell g3 15(1050,icore)((I am getting a new PC)and it apparetly my cpu is overclocked from its base 2.30 to 3.90 so i really wanna fix this because it is literally slowly killing my laptop almost always  80-90-100 degress so i need help. How would i be able to unclock it if that is possible..? Appreciate it
https://linustechtips.com/topic/1133715-cpus-help/
Can you get into the BIOS and reset defaults?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122482
Downoad Intel XTU and lower the the Turbo Boost Power Max. Try it out a bit since - in my experience - too low will make it run unreasonably sow, but too high is still too much..
For my scenario, 12.50W was the best. But just try it out and see what speed it goes up to in task manager.
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122483
Just now, AspectBh said:
Minibois which one do i try first the reset or the XTU?
Make sure to quote people or use @minibois so we see your responses
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122495
Try the reset first (I doubt that will do anything, since that is more applicable to desktop PC's and BIOS overclocking.
But doesn't hurt to reset, just gotta keep in mind you may need to setup the boot priority again
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122499
Good point.  I assumed 3.9 was a literal OC rather than boost.
Then again.. gaming laptop.  Ewww.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122505
3 minutes ago, AspectBh said:
@FasauceomeIt wouldn let me for some reason but ty any ideas? on which one i should do 1st? @minibois
Oh by the way, it's worth mentioning the laptop might have its fan system filled with dust, which may cause the components to root anyways.
Cleaning out the laptop will likely help too with thermals and noise
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122509
@miniboisi lowered the short power max and the boost power max its running at 3.00-3.33 GHz is that alright?
or should it be closer to the base 2,30@ @jstudrawa
What you have should be a good start.  DOn't set it to it's idle speed (2.3).  I mean, you bought it for a reason, so perform.  So let it.
Clean it, get it on a hard surface (not your couch, bed or lap), and let it breathe.  That should help a lot.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122601
40 minutes ago, AspectBh said:
@miniboiswell i dont have internet weird..  but im the xtu what now??
33 minutes ago, AspectBh said:
Any ideas @minibois@jstudrawa?? sorry for bugging you
Calm down with the mentions, I was away for not even an hour!
Don't turn down the speed too much. Only a little bit and clean the laptop's insides.
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122632
 Alright then this is the last tag i want a new pc for 1000 euros so i settled on
-Cooler master box Q300L
-Be quiet pure power 11 500w
-Asus prime H320M-A-R2-O
-Intel core i3-9100F
-GSkill value F4 2666 19D 16 Gnt
-EVGA Ge force GTX 1660 TI XC
-HP SSD Pci express 3.0 512
-I need left a 144hrz monitor, keyboard mouse mouse pad
(g-sync compatable monitor if possible w/ the card)
If you got a better one of this this one is bad just post it here.
Sorry for all the mentions and bugging you of your time
@minibois
I will only @ you again to thank you only.
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122660
@minibois
Feel free to quote/@ me, but three in a row is a bit excessive :P
I typically am quite thorough with replying to questions people ask me, but I am also not always online here..
So you currently have a build like this?
PCPartPicker Part List
CPU: Intel Core i3-9100F 3.6 GHz Quad-Core Processor  ($87.49 @ Walmart)
Motherboard: Asus PRIME H310M-E R2.0 Micro ATX LGA1151 Motherboard  ($65.62 @ Amazon)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($54.99 @ Amazon)
Storage: HP EX920 512 GB M.2-2280 NVME Solid State Drive  ($72.49 @ SuperBiiz)
Video Card: EVGA GeForce GTX 1660 Ti 6 GB XC GAMING Video Card  ($269.99 @ B&H)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($44.99 @ Amazon)
Power Supply: be quiet! Pure Power 11 500 W 80+ Gold Certified ATX Power Supply  ($69.90 @ Amazon)
Total: $665.47
Generated by PCPartPicker 2019-12-12 10:22 EST-0500
I would personally go for something like this, assuming you have a 700-800 USD budget.
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($119.99 @ Walmart)
Motherboard: Gigabyte B450 AORUS M Micro ATX AM4 Motherboard  ($84.99 @ Amazon)
Storage: Intel 660p Series 512 GB M.2-2280 NVME Solid State Drive  ($64.99 @ B&H)
Video Card: Sapphire Radeon RX 5700 8 GB PULSE Video Card  ($329.99 @ Newegg)
Case: Thermaltake Versa H15 MicroATX Mid Tower Case  ($44.99 @ Newegg)
Case Fan: ARCTIC Arctic F12 74 CFM 120 mm Fan  ($6.89 @ SuperBiiz)
Total: $776.73
Generated by PCPartPicker 2019-12-12 10:29 EST-0500
You get a lot more CPU and a lot more GPU for, but for a higher price.
As for peripherals and monitor, I would just go for the Coolermaster CK350 as a good budget keyboard, whatever mouse your personally like (as that is highly subjective) and something like the Acer Nitro VG240Y for a monitor (Freesync, which works on AMD and Nvidia, 75Hz, 1080p). Just make sure you get an HDMI cable with that monitor.
And make sure you have some audio stuff (speakers, headphones, etc.)
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122726
The thing is i'm trying to get a 144 hrz and all those components go together so maybe somehow i can make my current pc build that i want a bit better???
@minibois the keyboard mouse i will get i already got headphones but the game that i am playing is VERY dependent on Hrz. Sorry
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122833
Oh yea, didn't notice the 144Hz demand. Sorry.
The Sceptre C248B-144RN or Samsung CRG5 could work for that demand, if you are okay with curved. Otherwise the Acer Nitro VG0-23.8 looks good too. But to be honest, I am not that into monitors myself..
What do you mean with your first sentence?
I also want to stick with the CPU because i don't think is bad the graphics card i need gsync for and the monitor needs to be 144hrz thats basically all the things but if you can convince me then go ahead
Personally I feel like the 2600 is just much greater value, but if you want to stay Intel; you do you.
The Q300L case is also not that great for airflow, but it will work. Nvidia works with Freesync now too, so you don't specifically have to find Nvidia G-Sync panels.
The 5700 is also quite a bit better than the 1660 Ti, although the Nvidia card is not half bad for its price either.
But I don't really have any points of critique for your original build. I just feel like AMD has more value in that price range. Not sure how H310 would hold up, for example. Or if B365M is a better option.
https://linustechtips.com/topic/1133715-cpus-help/#findComment-13122858
  • 4 weeks later...
