Mixing PWM & DC fans
Solved by Mira Yurizaki,
Rather than answer each question you had individually, I'll try to go for the general approach. You can mix and match fans all day, the system won't care. The only problem with Non-PWM fans is they can't "spin-down" slower than PWM fans due to a minimum voltage required to even turn the motor.
So it's more of a question of finding that bare minimum point and seeing if keeping it there still generates too much noise for you.
Featured Topics
King_PIN ·
Posted in Home Theater Equipment4 -
kasdashd ·
1
Capt_Monk ·
Posted in New Builds and Planning4 -
10
1
2
